Unbelieveable!!!! Ive been running 3 amps without using a relay. I never thought it was needed...WRONG... Ive had this annoying buzzing engine whine noise.ive installed several systems and usually the noise comes from a bad ground rca's etc.. I checked everything, looked to smd for any ideas...I came across the thread about relays and i started to think??? remote turn on wire does just that it triggers the relay on each amp individually...so if theres not enough current after turning on the first 2 amps it will give it a partial on hence creating this annoying sound....So at my witts end i took a piece of hook up wire one end to the positive post on my batt and hooked directly to the whinning amp and presto!!! buzzing gone.....So i ran out and bought a 40 amp relay with a 5-gang dist.block and not only the noise stopped, i am getting a much cleaner output across the board.......so anyways i thought i would post this if it helps anybody....IMAG0646.jpg
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
wow i thought someone would like this...
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
I am about to do an install with 3 amps, and deciding whether or not to run a relay, so if I get noise atleast I know one place to look lol.... good info..!!
Running a sony double-din no navi unit.cant think of the mod # but from 08,good unit low voltage on pre outs only setback.
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
