I think your biggest challenge with this would be to find a way to effectively cool the coil without adversely affecting the mechanical movement of the subwoofer, and trying to keep the coolant separate from the cone/spiders.
I'm tuned in should you decide to do anything with this project :)
Haha, I hardly have enough money to fund my computer hobby. I'm only 17 and only run a small computer repair shop. I wish, I'd try this in a heartbeat.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
I'm running 5.0 daily on my i5 2500k...
but now for the question(s)
the part in the sub that has to be rated thermally like that is the voice coil. the voice coil is attached to the cone, the cone moves. Water cooling that would only add un-needed weight/mass which would GREATLY affect performance.
now onto amps. good amps have a thermal overload protection circuit that ~should~ protect it long before the amp can self destruct.
that isn't to say that water cooling isn't used, RF for instance uses water cooling on their bigger amps during the prototyping/benching process. The thing is, the people who would really need the extra cooling in the real world are the same people who burp their cars, or run a 30 second bassrace, then shut the system off and let everything recover. There's also the whole power lost through heat thing, and the fact that heat decreases conductivity, you're really running around in circles here and should just get the bigger amp to begin with.
If thermal capability was raised, you'd start running in to mechanical limits shortly thereafter. So you might be able to cool that subwoofer, but you feed more power to it and push it harder, something mechanically will fail.
:clapping: This is what I was going to say. Thanks for saving me the typing lol
Isn't there a Soundstream sub that can take like 10k rms burps even though I believe it's rated much lower? (Just read this on this forum a week ago) Wouldn't that be an example of a sub that would benefit from the cooling because mechanically is seems it can take the 10k rms? Sorry, I'm quite the noob.
There would be a couple basic things to consider regarding mechanical power handling
- There is the excursion limits of the driver, which can be controlled with the enclosure
- Possibly a different set of spiders to better control the mechanical motion
- The is the coil-cone joint
- And there is the spider-coil joint
Edit: Just brain storming out-loud here
How about putting some sort of water proof stretchable cover along the bottom of the spiders, then encasing everything from the spiders to the bottom of the magnet in some sort of closed container
Then have a nonconductive coolant sprayed directly onto the coil above and below the magnetic gap. Hook everything up in a closed loop system so there is no splatter/loss
Edited by SnowDrifter
Or possibly just AC the crap out of the inside of your box? Haha. Maybe route the AC in your car to the box. Don't know how cold that would get. Now we're getting into stuff about cars, which I'm also not that bright with, haha! :D
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Lol. That might actually work, at least a tiny bit. If I have been playing my subs for a while, the air coming out of my box starts to get warm just from the heat dissipation
I think having air channels of some sort would work better. I have tried sticking an air pump into the pole vent on my old level 5 before. It didn't do much though - the air went up and out the vent holes without being channeled across the coil haha
Yeah I think if the surrounding air in the box were ALL to be cooled, that'd be the most efficient way, instead of some water-loop or whatever. Damn I'd love to try this out some day haha.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Or perhaps drilling channels into it, kind of like the bottom plates on the new DC XLs and pumping cold air into those?
the sub is a no go. pointless really
but the amps... the science is there. im willing to bet though that you would have to remove some circuitry to allow it to want to make more power
otherwise you would just have a really cold amp
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Possibly, I have to leave my computer-source for now though. I will come back soon and check out if anything else has been added in this thread. Thanks everyone!
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
I believe thats how the bazookas worked. They had a hole through the bottom plate that ran up and through to the top plate around the coil. It never sprayed directly on just cooled the motor around it. The amps ran off of radiators built into the casing
I used to have one of the bazookas way back when. It was more of a pain in the ass to hook up more than it was useful. All it does is introduce a new series of things to take up space and more potential to have something fail. Anti freeze running into your sub/amps/electrical isnt the best idea
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
