I have 2 kicker comp 12s that run off a kicker zx750.1 and they all of the sudden dont want to play hardly at all. Some times they will hit once when I turn my car on or off. And it seems as if the subs are not workin when I turn the car off the sub will "growl" after about 10-20 sec.
Hmm, have you checked you connections, like your power wire, and ground?
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
i took a look at the speaker wires to the subs and found that one sub was running at 8-10 ohms and the other at 2. And I tried to figure out the growling noise and noticed that the subs will pulse once very slowly if it got a signal from the head unit(turned the key on fast and turned it on and nothing happened) and it sounds more like a scrapping sound.
blown woofer.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeap scrapping sound sounds like coil rub, you're gonna need new woofers.
2003 Kia Sorento
Team Subsonic Lows
Push on the center of the cone and see if it makes a scraping sound
What you are describing is a blown sub. Welcome to the club ;)
Make sure you set your gains properly next time so it doesn't happen again
wait are you testing it will its on?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
