youll be fine
i ran a 12" RE XXX with a 5,500 gothic
be aware though, power acoustik doesnt put out what they say they do, and they also will run hot.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Run them at 8 ohms
www.facebook.com/BILLatDivineCreationsPhoto
He was taunting me. He's all like "come at me bro!" So I'm like "I'm coming at you bro!" And he's like "hey, fuck you" *chomp*. Then I killed it. I win.
^^^ you have truly taken being a lazy fuck to a new level tonight, an MRE. WOW
You would have to run them at 2 ohms. I wouldn't dare run that amp at .5, let alone run it all. Even though PA is overrated to high hell, the SRX series IS only 300 watts. I'm pretty sure you'll see right around that much at 2 ohms from that amp.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
that amp will do like 1200w.
wire the subs like this and they should each be getting right around 300w. (assuming wattage halfs from 1 ohm to 2 ohms)
Run them at 8 ohms
That's what I was thinking, however I'm not sure that the amp puts out rated, he may not be in any danger running the subs lower.
Christopher
so...you built a box in about 3 hours?
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
  • Who's Online   0 Members, 0 Anonymous, 1830 Guests (See full list)
