what kind of vehicle, in a hatchback, or suv i would do the first, in a trunk i would more than likely do the 2nd
99 grand cherokee
port in the middle is usually better than port on the side. subs will load differently if the port is on the side.
edit: dont know if this is different from vehicle to vehicle, but equal loading would make sense to lead to a better sounding sub stage
Edited by Kranny
please explain how having a trunk dictates more of a neccessity for port on one side???
center port works in any vehicle, because each sub sees the exact same pressure and volume for the rear wave, that is not true for side slot port
The reason for my answer is that the first box is sub up port back, the 2nd is subs and port back. If those are the only 2 he would use, those are my decisions.
these orphans aren't going to feast on themselves
Yea but if they are in the same chamber with slot onto the side. Won't they still have the same pressure bc they are starring one chamber. I could see if they were in different chambers and one port on the side
after reading this thread, im considering building a new box. Ive had my subs facing the trunk and port firing into the drivers side wheel well for a while now. I think ill try subs and port back with the port in the center of the box...
cant you just do box 1 with port and subs both facing back?...measurements look like there is room to do it..dont understand why you wouldn't
also...why is it that everything somebody says will give you DB gains is always in 3db increments?...that should be your first clue that is more of a guess than proven!
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
