Which comp set best for me?
stipek
That makes sense and if that is the case I could just buy any set and put the tweets in the door and then buy a separate imaging set of tweets for the pillar. How does the wiring work for that? Just run both sets out of the same crossover?
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
ive grown partial of focals myself
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
The cross overs on the image tweeters have input from amp then output to main cross overs and output to the tweeters . Very easy to tie into your main system and doesn't even change your download to amp enough to make a difference. And my t set has great mid bass I have them crossed over at 50hz and it plays down low perfectly
I am definitely lacking midbass.....and have no deadening yet.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Heard by a few that the focals are bright and the k2 power line is the only good line but there are many factors that could come into consideration. What amp they had, crossover points, deadening, set up, vehicle, etc.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
u did say ur just putin them in the stock location if so that will have a big impact on how it will sound especially if they r spread apart like u r thinkin of doin
Do to the separation would I be better off with a 3 way set with the tweeter in the pillar or is that still going to have the same issue? Perhaps just mounting the tweeter on the top of the door would be best?
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
  • Who's Online   0 Members, 0 Anonymous, 1883 Guests (See full list)
