I want to get as loud as i can with the equipment that i have. I spoke to my shop today they said if i put the mike on the drivers side it might be louder, because thats where the port is, on the drivers side.
mic on drivers side, passenger door open, and make sure you are not sitting in your vehicle as you could be blocking it from loading out of the open door, and you arent allowed to be in vehicle above 145 anyways. Your equipment is more then adequate. You can likely see a 46 just by tinkering around and understanding your system better. 34 is a fairly low frequency to peak at, so dont be discouraged by bigger #s at higher frequencies.
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
well thanks everyone for their input. I will hopefully be at the fresno show to compete again. the shop i go to just got a term lab so now i have somewhere i can test run my truck at.
MECA's tough with the fusing. Stinger hi-amp fuses held up the best for me if you can find them. Still would blow 2 80 amp fuses in M3 off 2 Mmats HD4000s or 1 massive D16000. They would hold 2-3 seconds on average
2002 Civic Si
Soundstream VR 931-NBT
DLS UP36i components
DC power 320 amp alt
XS Power - (3) D3400s, (2) D3100s
2 DD 9515's all carbon with superchargers
Audio Control MVC processor
Arc Audio KS300.2
Sub amps - considering 2 T2500bdcp's for MECA M3
What's the lowest size fuse you think I can get away with? Will a smaller fuse result in me getting a lower score?
:spiteful:
Run some solder under a 60amp and call it good. :spiteful:
This guy lol...why not just hide a copper bar there also..... pretty sure that's cheating i don't run fuses never have..thats cheating
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
:spiteful:
Im aware. I am not guilty of this, but it is a route some take to Sand Bag a class which we all know is no better then running a lower fuse rating as well..
  • Who's Online   0 Members, 0 Anonymous, 720 Guests (See full list)
