So I was hooking up my sub/amp and I got it all hooked up and started a song my headunit said protect, I took the positive lead off my battery and tried it again and i got the same protect message. I made sure all wires were covered and tried it again but this time I had no power to the headunit. Ive tried fuses,re covering the wires, etc nothing has worked. Im stumped :/
what headunit?
what is the sub wired to in ohms?
what amp?
have you checked the rcas tried different rcas?
\/ will77530 this can help too you may not be hitting the recommended voltage
Edited by deathcards
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
pull the head unit out and go to the battery, put the red and yellow on the pos and the black on the neg. see if you get power their, and check the fuse on the back of the headunit while your at it, just in case
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
if they are grounding out or touching than yes. or at least throw it into protect or blow a fuse. Also some headunits require the antenna to be plugged in, idk if this acts as an extra ground or what.
pioneer h/u
1 XS d925
1 Stinger spv35
check all wires for worn spots where it could be grounding out
check ground could have come loose, bad/improper ground, check resistance of fuse if it is an open circuit it won't read anything
check power wire voltage, worn spots, and connection
skar sk2500.1
alpine HU
2 x-15 sundowns
