C1500 build. DC 9.0K, dual singer 350a, air suspension and Fi audio
This thing is gonna kickass. I was thinking about the corvette servo until I was talked into doing the Manual swap. Looks like you got the deeper pan also. Are you doing a bigger dedicated tranny cooler?
going to run a, for a lack of better terms, fullsize tahoe/suburban cooler?
Not sure if it's a 1/2 ton vs 3/4 ton thing, but I noticed that most 88-98 tahoe's and suburbans have tranny coolers that spanned the whole width of the radiator, unlike my truck that only spanned half of it.
  • 3 weeks later...
i'm going to try and get the biggest i can get. i wont be using the lockup so it needs more to keep cool
Wish i would have seen this earlier....
Do not do the 6link ( skimmed threw so not sure if your ordered it) its a POS if you have alot of weight in the bed, it wont lift.
I have the KP 6link.. 8" bags Amd it takes 160psi to even lift the trucks... And 70% of the weight is also infront kf the axel.
Im removing the cantileers and doing a bridge shortly... Woont bt a big notch since i do want to do a blow threw at somepoint, but i still want to beable to sit as low or lower then i am now so..
Also With 4 8" bags i run a 12g tank and fill to 200psi, i can get 2 full lifts out of it. With 4 viar 480s filling it, it took for fucking ever ended up doing an EDC and also running the viars still, from 160 to 200 now at idle i think it takes just iver a minute
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i already bought it. maybe i can fab up a bracket in the front links to help with the weight?
  • Who's Online   1 Member, 0 Anonymous, 1058 Guests (See full list)
