C1500 build. DC 9.0K, dual singer 350a, air suspension and Fi audio
used the stock small case to test fit and it looks small but the large case will fill it in. still not going to marks the holes since the large case mount are 1/4 wider
p.s cat decided to photo bomb me
11059676_827258533977744_794606264798629
11126231_827258553977742_123820770313807
11133894_827258580644406_933539030690197
which one? the first one, 2nd or 3rd?
the first one i designed it freestyle mode. the other 2 drawings was made by ram designs. im not going to use those design and go.. first one was before the sp4 came out. the second one looks like a total fail. he design it at 2.5 sealed which is too large for the sub. 1.75 to 2.0 is what it needs to be
did a bid of work.. after checking things out i decided not to send the alt in and spend more money on it to have the case changed.. i moved things around and found a way to do it. the original plan did not work so i have to redo the template for the dual alt bracket. i think it will work for when i have money to upgrade to hairpin.. still dual 350a does not sound bad at all
11102651_829183537118577_571548231895493
11083602_829183497118581_436237703106283
11036381_829183510451913_164164963430835
11091157_829183523785245_462183519125449
11091265_829183573785240_864149750292815
11112224_829183610451903_167674100273632
10985239_829183627118568_506457733673636
11081421_829183650451899_610939947226889
11070138_829183680451896_888733148974422
the tape on there was to add more cardboard to it.. i want the bracket to be as beefy as possible.. im also going to do a back support from the header to the alternator. with as much torque this engine has its better to have it solid
  • 3 weeks later...
got a few bolts and nuts from work and decided to work on the truck for a few minutes. the bolts fit the alt but did not fit the stock bolt holes on the bracket so had to buy a bit kit from auto zone. the cheap bits actually put in work and cut through the brackets like butter. so on with the alts a mocked up the cardboard with the alternators and drilled the holes to bolt it in. i took the time to do this to check for hood clearance and im glad i did. it avoided extra work with the steel plate and recutting. as you will see on the last picture i had a bit of clearance issues but it looks like its not much and can work on it once the steel is marked
here is how it will look
11096447_836458469724417_645516637593708
11000657_836458509724413_147334611523120
10407713_836458533057744_228013387161002
10410374_836458606391070_274946397770746
10372797_836458789724385_753541848395274
11149562_836459043057693_380923556432638
Putting in some work on this beast !
Pioneer 80PRS
4 Scan Speak discovery 4" full rage
2 Ampere Audio 6.5 Comp sets
3 Singer 370 Hairpin's
1 Odyssey g78/34-P1500
6 DieHard Platinum Marine g31
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Lots of welding lead & SkyHigh
Team DC AUDIO
