I belive you will have to turn the gain on the amp more.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
Higher preout means more power signal sent to amplifier= amp gain set lower = better for less distortion. Just saying. I have a JVC KD-BT1 I bought used for $50 and when i sold my amp to a buddy of mine i left the same settings on it. His Pioneer double din only had 2v preouts so in order for it to sound as loud as when the setup was in my car we had to turn gain up some more. So yes preouts voltage matter when you are looking for less distortion and tunning by ear lol.
But if you have a DD-1 or Osco, get either and just set gains using this. Amp is still going to put out same amount of power either way.
Under Construction
2011 Malibu 1LT
12k DDM Tuning HID's 55W
Soundstream 6.5 components(front)
Inffinitty Kappa 6x9's (rear)
will that cause me to draw more power from the car?
No. You set your gain to match your head unit's output. Gain works exactly how the name implies it does, it is how much strength the input signal gains before being sent to the driver.
I'm gonna hate
^ x2
Under Construction
2011 Malibu 1LT
But... 4 is bigger than 2!! :D
Nah- like everyone said, you just match your amps to the new RCA outputs. Higher voltage helps with distortion (like has been said) and helps keep voltage up if split to multiple amps.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
some amps dont like 2v inputs
REP
Use a line driver and call it a day
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
i used a dd-1 today on my alpine cde-122 and its 2volts. it did not clip at full volume
now if you where to buy that same head unit it might clip at 31 just depends
  • Who's Online   0 Members, 0 Anonymous, 4447 Guests (See full list)
