KenC210 Posted July 5, 2012 Report Posted July 5, 2012 So i would like to know what kinda programs to use to input different numbers to see how well a speaker would preform. I am not to sure if i asked the question right but its the best way i could ask at the moment. Like these numbers below FMS: 100.6 Hz QMS: 9.99 QES: 0.45 QTS: 0.43 RES: 21.6 Ohm RMS: 1.0 kg/s CMS: 0.16 mm/N MMS: 15.3 gr NREF: 2.29 BL: 8.1 SPL: 102 dB VAS: 10.5 l RE: 3.2 Ohm RP: 25.5 Ohm LP: 9.8 mH CP: 586.0 uF LE: 0.3 mH Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Robby Holmes Posted July 5, 2012 Report Posted July 5, 2012 idk sorry '08 Chevy Cobalt coupe 2.2 base model trunk build: 2 9512iSC flatwound alum 1.5 coils -extra 9500 spider pack -8" platinum carbon dustcaps 1 DD Z1 (.375ohm nominally daily) 3g31 AGM 320a Ohio Gen alt 1 DD S4 4 channel 4 VO-M8v1's (holes cut for 3rd pair) 2 CS 6.5's 2 VO-B1's Sony XAV-601BT all Knu Krystal RCA's Cadence 7band EQ ______________________ 148.3db @ 32hz (burp) 148.4 @ 37 & 38hz (burp) 146.xdb 90sec average (center windshield)
Joe X Posted July 6, 2012 Report Posted July 6, 2012 The new WinISD version 0.7 (at least) can be setup to simulate cabin gain, it will not be exact for a given vehicle but will a better approach of in car response. In any case limited information can be gathered from the plots this software produces.
siucsaluki11 Posted July 7, 2012 Report Posted July 7, 2012 ohh, i may put WinISD on my HP then.... woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
KenC210 Posted July 9, 2012 Author Report Posted July 9, 2012 The new WinISD version 0.7 (at least) can be setup to simulate cabin gain, it will not be exact for a given vehicle but will a better approach of in car response. In any case limited information can be gathered from the plots this software produces. Do i just download the pro version? or is there any difference? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Joe X Posted July 9, 2012 Report Posted July 9, 2012 The new WinISD version 0.7 (at least) can be setup to simulate cabin gain, it will not be exact for a given vehicle but will a better approach of in car response. In any case limited information can be gathered from the plots this software produces. Do i just download the pro version? or is there any difference? http://www.linearteam.org/download/winisd-07x.exe
