Calculating Gain Voltage?
doughboi916
How do I download off of ROE? I can't do it without buying quicktime... =/
EDIT: And what do I use pink noise for?
Pink noise is generally used to tune auditorium type settings. I've seen white noise used in cars more often for tuning. White noise gives equal power for each Hz, while pink noise gives equal power per octave. (Pretty sure it's along those lines).
Download a free version of Quicktime for the ROE downloads.
Need an install? Hit me up.
[email protected]
ok im woundering why you would set your dmm to AC volts? The only place you can find AC volts in a car would be inside of the altanator.
http://www.stevemeadedesigns.com/board/public/style_emoticons/default/01nocomment8so.gif
Be a man and learn how to do it by ear.
If your useing it with mids and tweets you would almost be an idiot not to beable to do it by ear.
Subwoofers are the hard part to do by ear.
You can do it man just take your time, find some good quality recordings (4 or 5 good CDs)
and when things start to sound crappy you know the amp is up to high.
Your ears won't lie.
actually "being a man" is doing it with an O-scope. Anything else is just guessing.
Follow my Tweet (Twitter)
just right click on the thing you want to download and click save as...
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
I agree but u can use a dmm to measure the voltage output!
A DMM won't show clipping. Just the output ACV. And that doesn't always yield the correct power you're getting from the amp. You would still have to go through and check impedance for each frequency, plug it in, and determine true power output.
[email protected]
