with those solo X's the bass hits so hard they knock your teeth out. Thats why they also included two mouthpieces.
1999 Jeep Cherokee SportLifted on 31'sPopcorn Sounds AX6000.1 w/ AA 500.1 "THE F1X" board4 Obsidian Audio OA15's
C pillar wall @ 29hz
^^^work in progress^^^
LOL! That too.
Such an advanced subwoofer that it can tell you if you are drunk!
I laughed more at the price.
Did JL replace the w7 with the solo x?
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
I wish my DD 9512 had a breathalizer on it that would come in handy, dayome!
haha but really, thats hilarious
Its the new "Super Subwooefer" its got an LCD touchscreeen on it, runs off of wifi and allows access to the android app store!
lol
Posted (edited)
Item weight 50 LBS
Shipping weight 141 lbs,
WTF are they packing this with
oh and you will only get 200 to 300 bass beats off the batteries
Product Description
* 1500 Watt Peak Power * 750 Watts RMS * 20 -100k Frequency Response * Efficiency: db 1W/1M 90.3 * Impedence: 4-Ohms Per Coil DVC KICKERs patented Solo-Baric square-woofer design lends itself to the most effective bassmakers in any vehicle, let there be no doubt. The squares size-to-decibel ratio remains superior to any woofer on the market, thanks to its 16-20 percent more cone area than a round woofer of a like size. The Solo-Baric L5 Subwoofer provides every bit of the effectiveness the technology offers, & the crushing bass as well. L5 may be the little brother to SoloX & Solo-Baric L7, but the differences are barely noticeable. L5 inherits the same inner workings as the L7, like the cutting-edge SoloKon, the vacuum-formed, ultra-rigid cone used to push massive amounts of air. & just as its predecessor, L5s motor structure uses high-temp dual voice coils, a poly-cotton semi-progressive spider, long-lasting tinsel leads, the effective UniPlate pole piece/back plate, & a T-cut top plate for dispersing heat & creating immense power handling. A wide Santoprene surround easily handles the punishment handed out by the L5s motor & cone, & a rear foam gasket secures the stamped-steel basket to any baffle. The steel basket w/spring-loaded terminals & a tough-looking magnet boot, the logo-bearing protective front gasket, & SoloKons hot matte finish make the Solo-Baric L5 rugged enough to take onto any city street. The four sizes of Solo-Baric L5 are available in 2-Ohm or 4-Ohm DVC & buckle pavement from sealed- or vented-box applications. Battery Life Approximately 200~300 times Warm Up Time 10-20 seconds Response Time 5 seconds Sensor Accuracy +/- 0.01 %BAC @ 0.02 %BAC Unit Dimensions - 1.33 x 4.05 x 0.98 inches, Weight - 1.87 oz. (with mouthpiece & batteries)
Edited by purplesyrup
  • Who's Online   0 Members, 0 Anonymous, 971 Guests (See full list)
