they can handle more power than it says.....
How much would you say?
I've been wondering the same thing, how much power will these REALLY handle?
so then which would you recommend?
d2 can be wired to 2ohm or half ohm-d4 can be wired to 4ohm or 1ohm
so it all depends on what your amp is stable at.
i wouldnt put more then 1000rms to em
d2 cannot be wired to 2 ohm, its 4 or 1, D4 is 2 or 8...for single subs... if you're running 2, then D2 gives you 1/2, 2 or 8 ohm. D4 gives you 1, 4 or 16.
he didn't say he was getting 1 sub or 2...im just saying how 2 subs will be wired..if he is getting 1 sub then you are correct, yes.
if you are curious on how to wire different subs with a d2 or d4 voice soils go check out
www.the12volt.com it will tell you everything you need to know
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
  • Who's Online   0 Members, 0 Anonymous, 482 Guests (See full list)
