which ANL fuse to get? does it even matter?
Those are the ones I use.
Note about using large fuses: If your wire shorts out, it will blow the fuse faster with a smaller fuse than with a larger one
I wire them with my amp loads. Even tho I have 2/0 wire that can carry over 300 amps of current I fuse a 150amp ANL fuse before my skar 1500.
Right on, HJ
My new amp(in sig) will require a 300a inline fuse so I'll have to switch everything to that. All my fuses are 200a right now, in accordance with my AQ2200.
97 Suburban
8 custom PSI Platform 3 18's
You'd probably be fine running a 200 anl fuse for the rockford amp. If not move up to 250 but you definitely dont need 300.
the way I check is 200x14.4=2880 watts
250x14.4=3600 watts
Edited by HunterJohnson
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
250x14.4=3600 watts
Your right HJ,
I run a 2hun on my 2500bdcp hot cable,... and its been more than fine....
and a 3hun on my alt charge cable
SPECIFICATIONS
MODEL- POWER T2500-1bd CP
Continuous Power Rating (RMS) - Measured at 14.4 Battery Volts
4 Load Mono 1,500 Watts x 1
2 Load Mono 2,500 Watts x 1
1 Load Mono 2,500 Watts x 1
Continuous Power Rating (RMS) - Two Amplifiers in bdSYNC Configuration
2 Load bdSYNC Mono 5,000 Watts x 1
Dimensions: Height 2.14" (5.44cm)
Width 8.14" (20.68cm)
Length 21.875" (55.66cm)
Battery Fuse Rating (Amp) External (Not Supplied) 300A
From the manual......I'm really confused now......
http://www.rockfordfosgate.com/support/rftech.aspx?kbsrc=http://rftech.custhelp.com/cgi-bin/rftech.cfg/php/enduser/std_adp.php?p_faqid=988&p_li=&p_topview=1#knowledge
97 Suburban
I only run 150amp fuses cause I don't need much more. 400 amp fuses are dumb for 1/0
DB link
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
  • Who's Online   0 Members, 0 Anonymous, 1211 Guests (See full list)
