More power more cubic feet?
BTW, if adding more power, you do not have to change your box volume at all. If it sounded good before, just keep it the way it is.
For severe over powering though, you usually want to adjust volume and tuning to make it safer to play under higher excursion.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Bump as in not as loud as a bang or a boom
Got it
Ed Lester
ShowtimeSPL Host
My old Build Log
I want to catch 51 hz peak at 45 hz so I can play thoes stand up bass songs one day
Can someone explain why I would need a smaller volume with more power
is this in correct chronological order from quietest to loudest?
Flack gun with that double bass
If your vehicle peaks at 51hz, you will most likely retain that peak if you tune your enclosure to 45hz.
However if you want to play the lower frequencies I recommend a tuning of around 32hz.
That low of a tuning will hurt your peak SPL and possibly lower your peak frequency.
The reason you would need a smaller volume with more power is because the speakers want to move more eventually to the point where the cone will rip itself out of the motor.
You need a smaller volume to "choke" the speaker a little so it doesn't tear itself apart.
Think of when you rev your engine. If it isn't in any gear and you rev it it will reach dangerous rpms rather quickly without a load on it.
However, if you place it in a gear with a load on it, such as moving your car, the engine doesn't rev out of control.
as Ed mentioned you should just keep the box the same if it already sounded good...and just increase the power...
now unless your going to be throwing a Shit Ton (that's slightly more than a Ton and less than an Ass Load) of power then you should be fine with the same enclosure
if your going for the Shit Ton or Ass Load category then you should decrease the volume of your enclosure
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
OP you need a translator...i hope english is not your first language, if it is, you need to go get some tutoring.....I can't make shit worth of sense out of the majority of everything you have posted.
  • Who's Online   0 Members, 0 Anonymous, 1123 Guests (See full list)
