ok after much thinking and reading im ready to decide to run my CVr 15's off my PA3000db at 1 ohm or not.
u see i want them to be loud (which they are) but i dont like my bass settings where they are right now. i have the gain (@ 4 ohm) set over half and the bass on the HU at half. so im thinkin there may be some dirty signal runnin through there (paranoid).
i was reading on here that at best the 3000db does 1600 rms @ 1ohm. so im thinkin thatll make the CVR's sound louder and i can turn down the bass settings on the HU giving me more clear high notes from stock speakers.
now wut im asking from u guys is whether or not u think this is ok to do. i will have the gains way down on everything and i wont be blasting music everyday full tilt. i just want a little louder from wut i have
whuddya think? yay or nay?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i say do it, 1ohm that bish finaly
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
yea 1 ohm that bitch!!!!
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
ive done a .5 ohm daily with a powerakiustic 2400db with no problem
your 3000db would be fine
lol man i wasnt worried about the amp i was worried about the subs
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
well have you done it yet? and if not, remember to properly set the gain on the amp to protect yourself .... i wouldnt recomend just jackin up the gains and powering the subs full tilt,... might end up with cooked woofers...
nope havent done it yet
and yea ima turn stuff way down then adjust accordingly
i gotta take the whole faceplate off to get to the back of the subs
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Use a meter.
I set my gains on my amp to give 800w (40v AC) to my 1600w sub and, uh, I didn't need all of it.
Is set it with my DVD Player volume on max (20) and I can turn it to 7 and hear a slight vibration of the walls in my room at only 0.7v AC.
I'm not saying that my stuff is better than your's just that usually you don't need full tilt.
Also, it could be the box placement and the fact that my walls are sheets of panel board.
I say set it to about 100-200 watts under the max combined and watch for the hot copper wire smell.
If you smell it turn it off let it sit for about an half-hour and turn gains down a titch.
