reg93f150 Posted July 13, 2012 Report Posted July 13, 2012 lookin to see if anyone has any box ideas for a single cab f150 `63 inches long 9 inches at the bottom 4-5 inches at the top 25-30 inches tall about 60 inches long at the top of the box got 2 kicker compvx 12 dual 2 ohm 750 rms 1500 peak got a concept cd-2410 amp to power them it can fit 0 gauge wire into the power ports and what not, was wondering if any of yall had a box idea or somethin or if yall could deisign somethin it would be greatly appreiciated more then you know, ill help out and supply as much information as yall need whatever yall need. Quote ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
safiend Posted July 14, 2012 Report Posted July 14, 2012 I'm looking for some ideas like this too. But with 2x Sundown SD-2's Quote New build coming soon..
hegar817 Posted July 14, 2012 Report Posted July 14, 2012 I had a 00 single cab silverado that i sold with my box. 55 wide, 15 tall, 10 bottom 6 top. Total of 3 cu for 2 12s and had to use 3 3in aeros ports tuned to 35 htz. Had 2 fi bl 12s on 2200 watts did a 145.3 at 41 htz. Aeros is you friend when it comes to limited space like i had. Hope this helps. Quote
reg93f150 Posted July 14, 2012 Author Report Posted July 14, 2012 anyone else got anything for this kind of box? id really appreiciate it, thanks Quote ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
reg93f150 Posted July 17, 2012 Author Report Posted July 17, 2012 bump~ Quote ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
bigmescan Posted July 17, 2012 Report Posted July 17, 2012 I have an 04 f150 for 2 sa8v.2's....box is not finished but it 36length 11bottom 5top 14high...........it has a 4in aeroport firing to the passenger side......I'm also 5 10 so I'm able to drive comfortably with this box............. Quote SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
