single cab ported truck box? 2 kicker cvx12's
lookin to see if anyone has any box ideas for a single cab f150
`63 inches long
9 inches at the bottom
4-5 inches at the top
25-30 inches tall
about 60 inches long at the top of the box
got 2 kicker compvx 12 dual 2 ohm 750 rms 1500 peak
got a concept cd-2410 amp to power them
it can fit 0 gauge wire into the power ports and what not, was wondering if any of yall had a box idea or somethin or if yall could deisign somethin it would be greatly appreiciated more then you know, ill help out and supply as much information as yall need whatever yall need.
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
I had a 00 single cab silverado that i sold with my box. 55 wide, 15 tall, 10 bottom 6 top. Total of 3 cu for 2 12s and had to use 3 3in aeros ports tuned to 35 htz. Had 2 fi bl 12s on 2200 watts did a 145.3 at 41 htz. Aeros is you friend when it comes to limited space like i had. Hope this helps.
anyone else got anything for this kind of box? id really appreiciate it, thanks
bump~
I have an 04 f150 for 2 sa8v.2's....box is not finished but it 36length 11bottom 5top 14high...........it has a 4in aeroport firing to the passenger side......I'm also 5 10 so I'm able to drive comfortably with this box.............
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
  • Who's Online   1 Member, 0 Anonymous, 734 Guests (See full list)
