DC Sound Lab
So, I was cruising down the road today with the tunes cranked; then out of nowhere I hear this horrible noise. I turn the radio down, and when I arrive home and inspected I found this:
It is a sad sight. I had two m2 lvl 4 12" subs off a crescendo 3500 at 1ohm. Box is at 3ft3 after displacement for the pair with about 17in of port per cube tuned to 33hz . The amp was tuned with a DD-1 on a -10dB tone. The death was probably my fault though. I was playing some decaf which I assume is boosted. Sad day today was...
Edited by stuntstere
I am running the same exact stuff. Except mine is in a 4th order. Dang it man WTH happened???? The amp has clip protection...hmmmmmmmmmmm
which sub went?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
what do you mean one side is open?
The meter reads OL. There is an open in the coil on one side of the sub. The other coil reads fine at 1ohm. So would loosing a coil cause this to happen?
  • Who's Online   0 Members, 0 Anonymous, 1896 Guests (See full list)
