Larson334 Posted July 14, 2012 Report Posted July 14, 2012 Hey guys I have been trying to find out the best way to wire dual voice coil 2 ohm dual l7 subs to a mono block amp and I do apologize if this is in the wrong part of the forum( I think this is right ). I know this is an easy question but after searching the web I have become frustrated with all these dumb youtube videos and bad advice so I came here. so I need to wire two kicker l7 dual voice coil 2 ohm subs to a mono block amp! Please Help! Btw Its awsome to be a part of this forum now! Hope I can learn tons!
SlamminBeats Posted July 14, 2012 Report Posted July 14, 2012 go to the 12 volt.com and go to the wiring guide. Easiest way to see it done.
CJ18 Posted July 14, 2012 Report Posted July 14, 2012 you can do .5ohm or 2ohm at the amp. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results
zack_e89 Posted July 14, 2012 Report Posted July 14, 2012 If both subs are dual 2, then these are the droids you are looking for: Option 2 (series/parallel) = 2 ohm load Voice coils wired in series, speakers wired in parallel edit: ninja'd by CJ18 97 Suburban 8 custom PSI Platform 3 18's
CleanSierra Posted July 14, 2012 Report Posted July 14, 2012 Like this: Edit-Ninja'd Im not the one you want to try to troll. Just a fyi for you.
zack_e89 Posted July 14, 2012 Report Posted July 14, 2012 Like this: Edit-Ninja'd Although he wasn't very clear, I think those are the wrong voice coils 97 Suburban 8 custom PSI Platform 3 18's
