Voltage drop problem BMW 325i
might have a faulty regulator, sounds like its just turning the alt off after you rev the engine. But it kicks it back on when drops back to idle.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
The thing I don't understand is why does the voltage drop so low after I rev engine up.
My 320A Mechman spikes up to 15.5V when I punch the throttle but never drops below 13.8V (warm) when I let off the gas and drop to idle.
Given I have an adjustable voltage module with it but it sounds like you may have a flaky voltage regulator of you're dropping in the 11's by just letting off the throttle. :shrug:
How did you installed yours?
Took out the stock alt and just installed the Mechman with the pulley that came with it.
I left the stock control header disconnected. It came with an adjustable voltage module instead that I ran to a relay that's switched by my ACC wire.
The pulley it came with is smaller right?
I tried both pulleys, stock and smaller one, and can't get the voltage to stay where it should be.
I'm not sure, I didn't compare them that closely. At a glance they seemed similar.
My old pics don't really show the pulleys together.
I'll try to measure them when I get a chance but I can't see how pulley size would account for your voltage to drop like that...?
I'm still thinking the regulator is flaky...
Today I found out that I have the opposite problem that you do. When my Mechman's "cold" it gives voltage spikes of at least 15.5V when I take off from a stop.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Looks to me like you might be able to get an idler pulley in place there above your power steering pump (whatever it is under the alt).
Use the two bolts it mounts on with and fab a bracket to hold a pulley that will increase the belt wrap on the alternator. If there's room.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
I talked to Mike about voltage drop and he said it's because "the alternator can't stay turned on since your not spinning it fast enough. It drops to resting voltage of the batteries."
So the problem is that alternator not spinning fast enough and belt slips a lot.
The only option I have is to get a much smaller belt. Which I did.
Stock is 60.5 and I got 58.5.
I think your alt has a regulator issue tbh
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I asked him about regulator and he said it's got nothing to do with it.
Hopefully belt will fix the issue.
Feel the belt after playing full tilt for a while. If it is superhot then that is an indication of belt slip.
With the voltage drop I'm having right now, I'm afraid of blowing amp.
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
