Im looking at a voltage meter, but it doesnt have a remote turn-on sensor wire. More specifically, Im looking into this http://www.sureelectronics.net/goods.php?id=1055
The volt meter only has a positive and negative input, and I want the meter to switch on and off with my HU. Ive been looking up relay wiring and think I found a solution. I just want either a confirmation or for someone to correct it. If you dont know, then dont post :)
30 = To 12v input of amp
85 = To negative battery post
86 = To remote turn on
87 = To voltage meter
87a = Not used
From my understanding, when pin 86 gets power, pin 30 and 87 get connected.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
switch, or splice into your head units accessory turn on?
hatersgonnahate has this exact volt meter i believe.. but i think he ran a switch.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Try measuring your voltage simultaneously. I'll bet the switched ignition {coming from your ignition switch} is within 0.02 volts of what it is at the amplifier.
I have 2 volt meters.. one that plugs into my cig lighter, and the one that goes straight into my amps inputs.
At idle and while driving around, theyre pretty close. Only .1V off or the same reading.. but when I turn my system up, they're totally different readings.
I dont want to take that risk.
Edit: yes, he does have that VM and runs a switch.
Edited by hdorre
LMFAO so true
:blush:
Good idea and yes that will work, you could even tie 86 to ign source so you dont have another accessory on your remote wire.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Shouldn't you be able to just put the positive wire onto the remote lead?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I was hoping someone like you would reply. Im getting the TORK2, so I should be okay :)
LMFAO so true
:blush:
I want to measure the voltage that the amp sees. Also, if I see the voltage the amp sees.. I can detect issues before they become expensive.
LMFAO so true
:blush:
I have the stinger volt meter with remote wire. Is it better to wire it to the amp or battery? I tried wiring it to my amp but it didn't work so I figured either I was wiring it wrong, the meter was broken when I received it or I didn't have the wire pushed in far enough and not getting a signal. I was just going to extend the wires and run it to my battery and the remote off my HU but it would be ten times easier to just go straight from the amp.
Vehicle: 2007 GMC Denali
Headunit: Pioneer AVH-8400BH
Sub Amp: Rockford Fosgate T-1500bdcp
Sub: Ascendant Audio Havoc 12"
Electrical: Big 3, Dual Batteries, Stock 160-amp alternator
Wiring: RF 0 gauge
Box: Custom built 1.89^3 net
I prefer to have the wire plugged to the amp and here's why:
I can detect any problems before its too late.
Examples..
-If the fuses from my front to back battery are blown, Ill detect the problem before I potenetially kill a bettery, two amps, and sound processor.
-If the fuse is blown going to the amp, Ill save the amp.
-I want to know what voltage the amp is seeing.
LMFAO so true
:blush:
The stinger meter is super easy to wire the wire are even colored for what they should be connected to
Red - 12v amp power
Black - amp ground
Blue - amp remote
Do that works like a champ.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 9650 Guests (See full list)
