The subs would have enough room i believe because my bottom length where they will be mounted will be 13 inches possibly more and the top of the box i want to be 3 to 4 inches where i want the port to come out my max across will be 60 inches and where the tranny comes up the bend in the back of my seats i am going to go around and then all the way back down to the floor again.
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
That should work pretty well, but you'll have more volume than you need if you go that far to the floor and that high up the back of the cab. You don't want too much air to those subs. You also won't be able to measure the volume of that weird area of the floor hump region, until you've made some kind of fiberglass shell and filled it with packing peanuts(easy way to check volume) to see what you have to work with right there. You should only need about 2 cubes net for those subs, not 3-3.5 like you will likely have if you use all the space you're referring to. I'm just trying to help, and I have the behind the seats measurements memorized I've crunched so many numbers for boxes back there.
so do you think i should just ignore the hump and run the box normal without it going way down there or go down and cut the top shorter?
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
I think you should run the VOLUME of the box above the hump, but trim the box all the way to the floor. That's what I did to make it look clean. I ran my port differently than you are planning on though.
Porting into the side of the truck is good but only if it has 3-4" of room before the panel otherwise you will choke it
Team Big Un,Team DB Drive, Team DB Driven, Team Xs Power
Team Ohio Gen, Usaci 2-4 modified champ 5 years in a row
where do you guys think i should run the port then?
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
Just Installed my new stinger voltmeter at 3AM last night :) and a dead battery :)
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
You can get 2.5 cubes net comfortably behind the seats. You'll have to build a step in the back of the box to go up to 18-20" since the highest you can go without a step is 13.5".
Port out the side Probly passenger side so you don't ever hear the port noise if there is any
