SMZ2's Xterror. 1st Hairtrick!
As promised some videos I took today excuse my crappy editing... there isn't any haha and please excuse the crappy camera even though it picks up flex well my phone was dying so I had to use the old camera.
http://www.youtube.com/watch?v=xU0U-LfAo_c&feature=share&list=UUUtd9sobeY0nczpn_L2arFQ
http://youtu.be/2hc3TFN2ucs
http://youtu.be/lHIYQoWqEJU
That's the whole purpose of the 4x4 blocks, it makes the surface you're drilling into 1.5" thick, so you can recess all the hardware (nut, washer, allthread) into the first layer, and then you have the second layer which is the little block.
I think, if you can, you should use it in conjunction with the angle iron. little extra bracing never hurt :)
I'll try to do a cutaway view in MS paint.
Okay that sounds like a plan. Also for filling in the port hole I guess I'll just cut out another piece when I double up the top to fit inside the old port screw it and glue it and then fiberglass it all in. So the box need these things to be finished proper bracing, sealed old port, doubled up top layer, and paint.
makes more since now. I'll drill the hole first then glue in the 4x4 block and that should work or atleast been alittle simpler.
Likin the vids, makes me wish I had more space to work with than the tiny ass trunk of my car! Keep up the good work man
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
now its time to seal it off babyy!
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
nice vids bro
Thank you sir
Thanks man. You could always wall the mustang man that would be freaking bad!
I've considered it I'm just not sure how to approach it...
Can I get some help/info on sealing off the box? I've heard I will get good gains and it will kill all my flex it the back of the car but how would I seal it off?
Use cardboard templates and try to get as close as you can to the walls use pool noodles or pieces of foam to completely seal it off. or weather stripping in some places.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • Who's Online   0 Members, 0 Anonymous, 2192 Guests (See full list)
