SMZ2's Xterror. 1st Hairtrick!
Looking good so far bro! Get it done...
Maybe you will give me the balls to try my own doors.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Good job finally figuring out where to put them!
Looks like it was a total pain to get all four of those on each door.
Also next time you can quickly put resin on the rings just to strengthen them before you start glassing and positioning them. Not necessary just precaution. Sorry about the particle board breaking.
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
Lots of kitty hair...
it's definitely ballsy man. Cutting the doors scared the crap out of me... but the doors will be back better than ever because of me cutting them. Thanks for tuning in.
I test fit the doors and they fit great for the most part. There is plenty of clearance between the door on my side. The back ring one the passenger door is very close to the seat though.
Thanks man.
It definitely was... I've learned to cut after to maintain some door structure.
I'll definitely have to try that next time I had to put some glue on some of the mdf rings because they started to separate. They will not be going anywhere now though.
Lookin like it might be loud!
Only tweeters will be in the A pillars? Those are some big fuckin tweeters sir.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Nice job man....
Thanks for stopping by bro.
This was only a test fit I plan to add a lot more kitty hair and resin. I just had time to sand and make sure things fit today.
I hope so!
Yes they will be and I'm glad you mentioned that... I've been holding out on pictures of the a pillars lol. They are in now. I plan to add some more fiberglass to them as well though.
There are a few imperfections in the doors and pillars since I could not get the fabric to stretch as much as I wanted but some sanding fixed that today. I'll just have to fill some spots with filler. I may end up wrapping the pillars and doors in black fur though. If I do this I will not need to worry about filler.
  • Who's Online   0 Members, 0 Anonymous, 2508 Guests (See full list)
