how to wire 6 10s
ZachG
the zx is 2 ohm stable, so you could buy dual 2 ohm subs, and you wouldnt need a h/o alt for 1500 watts. but i guess i get it if you want to get some money back, i totally understand that.
these orphans aren't going to feast on themselves
Yea cause I'm trying to get a some money back and re invest in like deaderner and maybe a 4 channel.
I actually have 2 zx1500s 1 used for 3 weeks 1 brand new sealed.
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
I've run my zx1000 at 1.33 ohm for 2years now with problem,
Also the zx1500 depending on elect won't see anywhere nere 1500rms
You'll be around 1300 @ 12.8v
And after box rise you will prob see less if at 2ohm final load,
Also look as the 2x sa12, them paired with a zx1500.1 Is a good match and you'll have plenty of left left over
My option is
2x sa12 around $390-400
1x z15v3 around $420-430
Both will be 2 ohm final load and use 1 zx1500.1
And allow you to sell the other 1
My option is
I may just do that then, I want to sell my brand new 11 zx1500.1 so I can start buying the subs and wood. I was asking 475. Do you think that's too much??
2 SA-12s on 1500W is perfect, so are 2 obsidians, there are better deals for the money though. Anyways on output 2 15s >> 2 12s.
I'd rather 2 15s cause the output but I don't think I could build that box properly. 2 12s for now would be good, plus my style car gets loud with very little.
Well thats how 2 SA-12s box could look like:
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 4.1 ft^3
External Height = 15.25 in
External Width = 33 in
External Depth = 24 in
Port Width = 4 3/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 13 15/16 x 13 3/4
2x Front Internal = 12 7/16 x 13 3/4
Back = 33 x 13 3/4
Left & Right Sides: 22 1/2 x 13 3/4
Top & Bottom = 33 x 24
Shared Port Internal Assembly Parts:
2 x Front to Back = 20 5/16 x 13 3/4
Fb = 34.5 Hz
Vb = 4.1 ft^3
Cut Sheet List:
Back = 33 x 13 3/4
Would aero ports be better or no?
If building the box with slot port is a promlem, then yes aero will be better, in you case
You could also look at something like a p3-2x12
It fits in your meserment and they sound good as well, I'm not sure on the us pricing,
It may be a prefab, but, t's one that work well and gets loud, and seen as your going to have trouble building a box it may be a good option to look at
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
