wonder if you unsolder those 2 8g runs and resolder new ones if that'll fix your issue, some people acually upgrade those wires to 1/0 if they have the room and see like a 15-20% output increase in clampped numbers, i had a stetsom 7k2d that was "modded" like this, did like 9.8k clampped after the guy did it
1/0 is pushing it cramped for space in there might be able to get away with 4 gauge
for this amp you prolly cant do 1/0 but ive seen it done with others, 4g prolly though
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
All the rca wiring connections look good. The gain pot and connection isn't loose. I think it may be the big wires, one is output and one is ground, so if they're bad, could be the problem. I will not be attempting the repair however LOL
SMD Super Seller
My Feedback Thread
ya i def think the 8g wire needs to be upgraded to like 4g...
*** 1991 Turbo Walled Civic 400whp @ 20psi ***
- JVC KDS88BT Headunit - 4 15" Fi BTL N2 Fully Loaded Subs - 1 SD16kD Amp - 14.5ft^3 Wall Tuned to 37hz with 202in^2 of port - Mechman 220a HO Alternator - 6 XS Power D3100 Batteries - Copper Buss bars - 2 Runs of 4/0 Welding Cable - Big 3 - Stinger Digital Volt Meter
Burp outlaw in the kick: 158.9db
Music: 157.5db
Sealed on the dash: 157db
- SPL Labs Rep for Missouri -
Someone said it was due to the RCA's internally, but it might have been due I had an rca end brake off it's grounding strap inside the RCA. So it was intermittently grounding, and not grounding. So guess I'll either send it to Db-r or someone else. Stuff like this happens. Name of the game.
formerly known as Blue86f150
this sux camel dicks
  • Who's Online   1 Member, 0 Anonymous, 4431 Guests (See full list)
