Things to know about running .5 ohm.
Semper
So, what are things I should be aware of when running at .5 ohm.
Crescendo: Are these okay to run @ .5 ohm daily?
Impedance rise: If you're @ .5 ohm and you're getting box rise, how long until the impedance stops rising. What factors are involved and what pre-cautions can we take to minimize box rise when running @ a low impedance.
Pros & Cons?
Is .5 ohm only used for competitions and is it okay for daily setups ( gain all the way down, bass boost all the way down [lolalways] )?
If I were to run at .5 ohm, what could cause my amp to fry and why. Would it take my subs out with it, or just the amp?
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
Well, from what I've read, you need very good electrical to run .5 ohms, and Crescendo says you can do .5 ohms with good electrical.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
doesnt running .5 ohm draws double the amount of amps? would rather much run 2 amps and get twice the power than to run .5 ohms for just a few hundred watts and risk frying equipment
I'm sire, but what's considered 'good enough'
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
I would only run .5 ohm for maybe a competition, other wise if you wanted more power, why not just upgrade the amp? Inside of risking frying something with almost doubleing the current draw.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
because I have d2s. Its nearly impossible to find an amp to push 2k @ 2 ohms without spending 500 dollars.
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
Depends entirely on the amp. If your amp is rated at 1 ohm and 80% efficient there (thats being generous) then at .5 ohm it may only be 60-70% efficent depending how far you push it, assuming you have the electrical to keep it happy and that its guts can keep up too.
In short, dont bother pushing your equipment beyond its rated tolerances if you dont want to be replacing it.
Hammerdown... 1%
long story short, you get what you pay for.
if you spend $200 on a 3.2k amp, you wont be getting 3.2k guaranteed. (aka what i've done)
whereas if you spend $700 on a 3.5k amp you will almost always be getting 3.5k if not more.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
  • Who's Online   0 Members, 0 Anonymous, 1360 Guests (See full list)
