samorgan4 Posted July 25, 2012 Report Posted July 25, 2012 Hey guys still a new guy around here and wondering if it helps, hurts or doesn't matter if the amp grounds are larger than power supply lines? Ensuring correct power gauge line is selected of course. Thanks Quote
Wicks Posted July 25, 2012 Report Posted July 25, 2012 Assuming the smallest wire is adequate, larger wire elsewhere never hurts. Keep in mind that the system is still limited by the smallest wire so don't expect too much. Quote This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SnowDrifter Posted July 25, 2012 Report Posted July 25, 2012 It will help, not hurt. But this is assuming you have an adequately sized power wire in the first place. Don't shrink it so it's smaller than the ground, that will hurt. IMHO use the biggest wire you can for both power and ground Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
samorgan4 Posted July 25, 2012 Author Report Posted July 25, 2012 Thanks everyone. 1/0 from the battery. PDX M12 for subs requires 4 gauge. I would have liked to have run 1/0 to the M12 buy it will not fit even with quage reducer. I thought about cutting some of the strands off to get the wire in the slot. Would that work? The other amp PA D4000.4 has a 1/0 adapter so no problem plus I have the 1/0 wire already on hand. You guys are really something! Thanks! Quote
SnowDrifter Posted July 25, 2012 Report Posted July 25, 2012 You could cut it I guess, but what I would do is run the 0 gauge to a distribution block, then run 4 gauge out of that to the amp Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Omega5002 Posted July 25, 2012 Report Posted July 25, 2012 http://www.amazon.com/Sound-Quest-Gauge-Ground-Reducer/dp/B005A4SCWE/ref=sr_1_3?ie=UTF8&qid=1343185948&sr=8-3&keywords=0+to+4+gauge Quote 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
samorgan4 Posted July 25, 2012 Author Report Posted July 25, 2012 Good those were my intention And I havetyne 0 to two 4 on hand. Thanks guys. Moving forward with confidence sure helps. Quote
samorgan4 Posted July 25, 2012 Author Report Posted July 25, 2012 For the record the sound quest 0 to 4 won't work in alpine pdx power/ ground supply connector due to the geometry off the off sets. Way to go alpine! Thanks for suggestions on the terminal adapters. The stinger adapters won't even come close to fitting in the post. WASTED MONEY WITH GOOD INTENTIONS! Quote
dkindle613 Posted July 25, 2012 Report Posted July 25, 2012 The sound quest adapters also will NOT work with a RF T1500.1bdcp. I bought them thinking I can finally run 0 gauge to my amp, but nope, because of the fucking offset on the adapters.. Quote WARNING: I speak 4 languages, profanity, English, sarcasm & real shit 2003 ford explorer 2 RF T1 D4 15s in a 6.8 cubic ft box 1 T1500.1bdcp 250amp ALT by Mike Singer 2 runs of 0 gauge 3 yellow tops
