Single 18 box help
Jay L.
I just did some trading and got a DC M1 level 4 18, D2. I have a Saz3000d, and a Kenwood with 4v. outputs. Alternator is in the works, and I'll use 1/0 wire for +/-, and 2/0 for the alt. charge wire.
Can somebody spec out a good box for this setup? This is going in a Explorer, is sub- up port-back best? If so, could the port be towards the top of the box viewing it from the back? "Octoport?" Something cool. Maybe some fiberglass? Im looking for a challenge. I'd like the box to sit against the back seat, about 10° at that surface. Max. w-35" left to right, h-18", l-20".
I dont see myself competing, I just want what I have to sound like it should. I listen to mostly Skrillex, Bassnector, Deadmau, rap stuff. I look forward to seeing what you come up with, thanks!
With those dimensions i get 5.92 gross, no displacement of sub, port or double baffle. Is that your MAX dimensions?
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
OP you are short on space, your setup won't perform well like that. Less so if you are trying to fit this in a trunk car.
More space is needed
A lot more space
Why 35"w miss explores are at lease 40
And you should be able to do 20-22high
What is the
Height of you window
Height of seat
Height of headrest
Width between wheel arches if side wall
And 20"d how far is that from rear wall
Another thing angle of rear seat, or at least the the depth and height of it(you may need it
Width-45", height-18-20", length (or front to back)-will 20" be enough? I'd like to keep some space open in the very back of the cargo space. The height of the backseat is 18", and the upright portion of the backseat is about a 10° angle. Is this enough space?
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
