im getting alot of cancelation between 32-40 hrz any ideas that wont make the port longer than 18 inchs
box is 22.75h 48w 34d port is 14x14x16.5L 15.7 before woofer displacement current tune is 35hrz
Uploaded with ImageShack.us
REP
Unable to help. Wanted to say nice box.
thank you
REP
bass between to freq is hollow u can feel it but you can not hear it
REP
with out knowing all the info
im aussimg there 15"
this is what you built
this is probley closer to what you have
Idd say to start port is too small,
and without knowing anything about how you built it, or bracing, your tuning is probably higher then 36hz, so that would explain why,
post some more info on what you have, power and anything to do with box and bracing (pic never hurt) and will see if we can help some more,
but im assuming your tune is probably closer to 37-38hz
no bracing yet but im glassing in a 2x4 dead center top to bottom . its running a saz-2500 on 4 sa-15's and yes it feels like im tuned to 40ish because 45ish is the loudest and most intense and the vehicles RF is 41
Edited by bdog
REP
and yes your torries is bang on what i did
REP
I see you have a removeable port, you could just build another longer port,
idd try to do 2 common walls
this is what i would do
you can go upto half the port width from the back wall,
but at 10w x23.25d you have 32hz
or 9.5w x 23.75d 30._ hz
just dont go under 9.5w
Well it's not the tuning I just made a 30hz port for it and didn't make much of a difference if any . Could it be box flex and roof flex ?
REP
