shotime216 Posted July 28, 2012 Report Posted July 28, 2012 How can I make mids louder. here is what I have I have 4 Eminence Eminators Nominal Basket Diameter 6.5", 165.1mm Nominal Impedance* 8 ohms Power Rating** Watts 100W Peak 400W Resonance 119Hz Usable Frequency Range 100Hz - 5.3kHz Sensitivity*** 93.4dB Magnet Weight 20 oz. Gap Height 0.24", 6.1mm Voice Coil Diameter 1.5", 38.1mm i have a american bass sq 3000 Power Output (DC 14.4V) RMS at 4 Ohm, Mono 1000Wx1ch RMS at 4 Ohm, Stereo 300Wx2ch RMS at 2 Ohm, Stereo 500Wx2ch Max Power 3000W S/N Ratio >100dB THD 0.02% Channel Seperation >55dB Input Sensitvity 0.15V-5V Input Impedence 47KOhm Slew Rate 10V/Usec Damping Factor 200 at 4 Ohm Fuse Rating 30A x 4 My question is why is it that my friend has less speakers and a smaller amp but his vocals a louder? A few people said that my amp was "to big" which I dont understand how can that be. I also have a 3 way crossover and little 2 channel crossover. If ANYONE HAS ANY IDEAS on what I can do to fix this I would greatly appreciate it. Thanks.
BEEMDUB Posted July 28, 2012 Report Posted July 28, 2012 heres a hint...caps lock and exclamation points normally gets you help a lot slower..
blownengine Posted July 28, 2012 Report Posted July 28, 2012 More speakers. Simple. Boom 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
OrionStang Posted July 28, 2012 Report Posted July 28, 2012 How can I make mids louder. here is what I have I have 4 Eminence Eminators Nominal Basket Diameter 6.5", 165.1mm Nominal Impedance* 8 ohms Power Rating** Watts 100W Peak 400W Resonance 119Hz Usable Frequency Range 100Hz - 5.3kHz Sensitivity*** 93.4dB Magnet Weight 20 oz. Gap Height 0.24", 6.1mm Voice Coil Diameter 1.5", 38.1mm i have a american bass sq 3000 Power Output (DC 14.4V) RMS at 4 Ohm, Mono 1000Wx1ch RMS at 4 Ohm, Stereo 300Wx2ch RMS at 2 Ohm, Stereo 500Wx2ch Max Power 3000W S/N Ratio >100dB THD 0.02% Channel Seperation >55dB Input Sensitvity 0.15V-5V Input Impedence 47KOhm Slew Rate 10V/Usec Damping Factor 200 at 4 Ohm Fuse Rating 30A x 4 My question is why is it that my friend has less speakers and a smaller amp but his vocals a louder? A few people said that my amp was "to big" which I dont understand how can that be. I also have a 3 way crossover and little 2 channel crossover. If ANYONE HAS ANY IDEAS on what I can do to fix this I would greatly appreciate it. Thanks. How do you have the speakers wired to the amp? SMD Super Seller My Feedback Thread
Kyblack76 Posted July 28, 2012 Report Posted July 28, 2012 ^^^^ This,... looks like some drivers are 8 ohm correct? Also,... with your x-overs,... where are your set points set at?... I dont really understand your set up......(running the 4 on 2 channels, or all 4 on seperate ) ..... I would like a lil more info if you can provide...... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
jhmeg2 Posted July 28, 2012 Report Posted July 28, 2012 run two of them in parallel to 4 ohms, then use two channels to run them. two speakers on each channel ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
