Just finished putting some finishing trim on the wall in my charger and I go to take a final video, so I put the volume on low and my rca level knob was at about 2/5...Everything was working fine...Subs were playing amp was on all normal etc...So then I restart the song and turn the volume up and turn my rca level knob all the way (so full tilt) for my video..Bass hits...plays for about 5 seconds then cuts out COMPLETELY...to avoid suggestions of solutions that I already have done heres a list of what I have done
1. Checked amp is getting power and made sure voltage is the same before and after fuse
2. Checked subs...All connections are intact and final load reads 1 ohm
3. ATTEMPTED to check rcas with dmm...I put the negative to the outer shield and the positive on the inner pin read nothing.... Did it too the other rcas to my 4 channel and they also did nothing so I may have been doing something wrong?
Edited by BEEMDUB
And you check the RCA's with the head unit on, so you can read the voltage of the signal coming through it.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
yea I had music playing....alls I do is put the negative prong to the outer shield and the positive prong to the inner pin right?
Yup. Like bassface said, take the bass knob off and check the signals coming off those RCA's. I
voltage drop?
noope
and alright doin that right now
