BEEMDUB Posted July 29, 2012 Author Report Share Posted July 29, 2012 rcas are getting voltage both with and without the knob so rcas arent the problem... Quote Link to comment Share on other sites More sharing options...
BEEMDUB Posted July 29, 2012 Author Report Share Posted July 29, 2012 is there a way to check and see if my amp is putting out to the sub wires? Quote Link to comment Share on other sites More sharing options...
HatersGonnaHate Posted July 29, 2012 Report Share Posted July 29, 2012 Turn the DMM to AC Volts, turn on music, and measure the volts at the speaker terminals on the amp. Quote My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car. Link to comment Share on other sites More sharing options...
crispy_chick3n Posted July 29, 2012 Report Share Posted July 29, 2012 (edited) is there a way to check and see if my amp is putting out to the sub wires? dmm on ac voltage, and on the output of the amp would be what i would say.if you get a reading while you have something playing, you have a signal fromthe amp. that doesnt say how good the signal is, just shows that the amp is putting out edit: ninjd Edited July 29, 2012 by crispy_chick3n Quote This page is crispy_chick3n approved. © crispy_chick3n inc Link to comment Share on other sites More sharing options...
BEEMDUB Posted July 29, 2012 Author Report Share Posted July 29, 2012 Turn the DMM to AC Volts, turn on music, and measure the volts at the speaker terminals on the amp. is there a way to check and see if my amp is putting out to the sub wires? dmm on ac voltage, and on the output of the amp would be what i would say.if you get a reading while you have something playing, you have a signal fromthe amp. that doesnt say how good the signal is, just shows that the amp is putting out edit: ninjd dmm wasnt reading anything out of the amp speaker outputs > Quote Link to comment Share on other sites More sharing options...
ALPINE408 Posted July 29, 2012 Report Share Posted July 29, 2012 (edited) So you have no voltage drop when playing full tilt? I highly doubt that and is your amp 1 ohm stable? Subs cut out for a few resons Voltage drop Wrong ohm load Wired wrong Bad ground or power connections Pushing the amp past its limits Having a fucked up sub/ tinsel lead Wich one of those are you guilty of? Edited July 29, 2012 by Team Bassick (ALPINE) Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
HatersGonnaHate Posted July 29, 2012 Report Share Posted July 29, 2012 The amp has power? Check the fuses? Quote My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car. Link to comment Share on other sites More sharing options...
BEEMDUB Posted July 29, 2012 Author Report Share Posted July 29, 2012 So you have no voltage drop when playing full tilt? I highly doubt that and is your amp 1 ohm stable? Subs cut out for a few resons Voltage drop Wrong ohm load Wired wrong Bad ground or power connections Pushing the amp past its limits Having a fucked up sub/ tinsel lead Wich one of those are you guilty of? no I mean I don't have bad voltage drop..I stay above 12.7... everythings wired correctly sub leads are all good...I'm guessing at this point its the amp...I mean idk what else to assume..Even though I've never played it clipped, and have ran it at 1 ohm for quite a while...I don't even play em full tilt for more than 2minutes... Quote Link to comment Share on other sites More sharing options...
BEEMDUB Posted July 29, 2012 Author Report Share Posted July 29, 2012 The amp has power? Check the fuses? it lights up...and I don't see any fuses on the outside of the amp Quote Link to comment Share on other sites More sharing options...
ALPINE408 Posted July 29, 2012 Report Share Posted July 29, 2012 What amp last possible thing id something fucking up on the rca side be it the deck or a bad rca Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
