CHILLYBEAR5504 Posted July 30, 2012 Report Posted July 30, 2012 I just installed a Rockford Fosgate T1000-4ad in my 2010 dodge charger and when I turned on the vehicle there was alternator whining. What is this caused from and how can I fix it? It's really annoying. Thanks
SnowDrifter Posted July 30, 2012 Report Posted July 30, 2012 Ground the sheath of your RCAs to the casing of your head unit, and ground said casing if not done so already. Double check all connections, and make sure your RCAs are both shielded(optional) and not running next to or near your power wire ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
stuffdog3 Posted July 30, 2012 Report Posted July 30, 2012 ground the sheath to the head unit. What does this mean. I'm sorry to post jack but I'm having the same problem. Could you explain what it is you mean in depth please. Sorry if I'm dumb.
adreano17 Posted July 30, 2012 Report Posted July 30, 2012 search RCA ground fix. its all over the internet. Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
