Hello everyone i need some advice on a box for 2 alpine type r 12 for my dodge charger should i go ported or sealed
Ported without a doubt, post some max dims for a box and I will issue some build plans for you.
Ok here is a suggestion:
Enclosure Specifications:
Fb = 34 Hz
Vb = 4 ft^3
External Height = 15 in
External Width = 33 in
External Depth = 23 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 33 x 15
Left & Right Sides = 21 1/2 x 13 1/2
Top & Bottom = 33 x 21 1/2
Shared Port Internal Assembly Parts:
2 x Front to Back = 19 3/8 x 13 1/2
2 x Extension = 15/16 x 13 1/2
Assembly guide (generic dimensions):
Any changes comments or questions, let me know.
EDIT: OP, as pointed out below this suggestion assumes that you are running about rated power, and that you know you can fit the box in it's way in or that you are willing to build inside the trunk. As before let me know any changes you want made.
Edited by Joe X
how do you design a box with out knowing what kind of power he is running and what kind of music its for
x2
But the funnier part is, how does he know the box will fit thru the trunk opening.. LMAO
because I have built several trunk boxes for chargers, and on the last 2 boxes I had made a box out of cardboard to the external dimensions of my designs to ensure they fit.
Telling you right now, 13inches was my max height and barley cleared, and the box was only 33wide, 35 wide is going to force you to have a stepper angle while installing the box, that stepper angle combined with a taller box may not give you the space to clear the top of the trunk lid opening...
To the guy starting this thread, I would SEVERELY stress you to make a cardboard cutout box held together with tape to ensure it will fit. Its getting rather close to not fighting juding by a box that I just measure sitting in my house from a previous charger install.
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
