'04 Honda Odyssey.....VuDin + Fi SP4 + 4th order + Sundown
My Pioneer 4200 died on me while on the way to a comp a couple weeks ago. I was using a 2v Pioneer HU for the time being but ordered a Pioneer 8400BH as a replacement. It's a nice upgrade, I like the features. Just need to get around the e-brake bypass because the relay way doesn't work anymore.
If you don't mind me asking, how did/are you attaching the Plexi to the wood on your enclosure??
1/4-20 flathead phillips head bolts and t-nuts with 1/8" foam where the plexi sits
New RCA's, some fuses and the badass alt from MechMan
I have 4/0 welding wire running from the alt to the rear batts. Positive and ground of each wire, I basically gave up trying to route the wire outa the way. I said fcuk it and just went across the engine cover
I had some enclosure-ish things bolted to the doors to hold my mids and a tweet. I was sick of them so I decided to try fiberglass. The crescendos looked much nicer than the seleniums so i said why not. Never did a door before but I think it came out pretty good. Wrapped with fleece, resin, chop mat, sand, body filler, sand, more filler, beer, sand and more fckn sanding. I sprayed them with some texture paint for the time being but eventually I'll wrap them with vinyl when I get ambitious. Added some LEDs for the hell of it.
What they used to look like:
And what they are now:
