Sub enclosure shape
cheebs
i am thinking about a box for 2 sa-8 v2. i was wondering if shape mattered? if i kept the volume and port volume the same would it matter what shape the enclosure is? and what about the sub mounting? i would love to have the sa-8s inverted. does it matter where i mount the subs as long as it is in the main camber? i have read a lot about how long some ports for these subs can be so say could i make a port that goes from one side of the box to the other and exit out the bottom in a L shape? making more of a wide port than long? i can build a great box but i will admit i don't understand the tech behind what i am building. i have build many boxes for myself and others and they almost always work out.
-port length really isnt an issue unless it is a TON of turns
-shape doesnt really matter too much but does play a part
-inverted is just as fine as regular mounting, just make sure the surround doesnt hit because if it rubs at all it will tear the surround and be bad news
-with ports, dont go too skinny is a biggie, maintain so to speak a 1 : 8 width to height ratio. (ex. dont have a port 1 in wide and 16 in tall)
What vehicle are these going into?
the sa8 are a killer sub but require either a 2x3" x26" or 1x4"x 23" for 33hz @1.2net if using aero's
or 19-23sq" of port for slot,
they require longer ports due to being in such a small box
post some dia, of you truck and see what fits
it's going in a car trunk. a 2000 c230 it's a small car. what space i am trying to work with is top 8"- bottom 13"- height 18" - wide 33"
Here is a suggestion for a box:
Enclosure Specifications:
Fb = 33.8 Hz
Vb = 1.2 ft^3
External Height = 13 in
External Width = 33 in
External Depth = 13 in
Port Width = 2 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 33 x 13
Left & Right Sides = 10 3/4 x 11 1/2
Top & Bottom = 33 x 10 3/4
L Port Internal Assembly Parts:
Front to Back = 8 1/2 x 11 1/2
Extension = 26 1/4 x 11 1/2
Extension 2 = 2 3/4 x 11 1/2
Assembly guide (generic dimensions):
Let me know any questions.
Fb = 33.8 Hz
Vb = 1.2 ft^3
Cut Sheet List:
if i can't find a way to do what i want i might use this one. if i wanted to use an areo port instead of a slot in this box what size would i need?
why exactly does jacob not recommend a sealed box for the sa-8 v2 but has a spec for it on the sundown site.
The sub has an EBP of 97 so is appropriate for ported enclosures, sure you can drop it in a sealed enclosure if you really need to, will loose bottom end and overall output.
how much low end what are we talking about here? if a good tuning is 35hz does sealed go up to say 45hz? just guessing here i don't have a clue.
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
