I have 2 L7s DVC 4 ohm. Checked the resistance on the series and it reads 1.5 ohm. I wired for 1 ohm. Is this normal?
Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
is 1.5 after you wired them in parallel?
no, SERIES.
no, SERIES.
well, something isnt right.
what is your ohm reading per coil?
series should increase the resistance not lower it.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
did you do this?
because thats the only series/parallel you can do. unless you did just series, which means you'd get like 16 ohms.
your wiring is fucked up somehow, or you're using the wrong wiring terms
no, SERIES.
All 4 VC measure ~4.4 ohms. I am using 10 ga speakerwire that has .5 ohm resistance when measured. I wonder if that extra ohmage is from the wire??
did you do this?
nah you can wire negative to negative, positive to positive: http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
series: 1 ohm.
no, SERIES.
did you do this?
series: 1 ohm.
That's wiring in parallel, not series. You might be seeing the resistance in the leads of the multimeter. Touch the leads together and see what it reads...if it reads about .5 then that's where the extra .5 is coming from, and means your actual load is only 1 ohm, not 1.5.
Edited by sprkn_ranger
no, SERIES.
did you do this?
nah you can wire negative to negative, positive to positive: http://a248.e.akamai...ono-low-imp.jpg
series: 1 ohm.
LMAO sorry for the confusion between the 2. :Doh: It does read. .5 for when the 2 are touched. I just changed the batteries on the damn thing, and need to recalibrate it (kind of suspected). Thanks everyone for the help.
  • Who's Online   0 Members, 0 Anonymous, 1018 Guests (See full list)
