ehh what the hell went wrong? need help
ok guys here is my prob, i wanna say i know the answer but ill let you guys decide, the ground wire i had for my battery/amp i replaced bc when i soldered it i did it wrong, i could move the wire and the solder would move as well so i replaced it with the wire i was using for my alt + to battery + i got it off a guy and it was soldered correctly so i dont have wire from my alt to battery i just have the stock wire witch is 12g so i replaced my ground with that, i moved the ground over a hair and used self taping screwes and star lock washer, its tight as hell, thats how i had the old ground as well, now here is the prob, i turned my car on and my volt meter was reading 12.5 so i took a dmm and did the battery and it said the same thing, went under my hood and checked the alt to battery to see if it was charging it and all it was saying was 1 so i have no idea why that is, i did my battery under the hood and it said 12 but went to 13, when i shut the car off and when back to read my back battery it was reading 13, why is this going on? is it bc the stock wire is to small to charge it or what, when i did everything the back battery was disconnected
You need to ground your battery much better than with 12 gauge and a self tapper. And wait are you saying there is no connection between your alternator and battery?
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
Alt isn't connected in the circuit simple as that, check you alt + connections.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
im using 1/0g and self taper with star lock washers is actually really well, i used 2 of them for a good solid contact. the 12g stock wire is from the alt + to battery +
i put the dmm on alt + then battery - and it was reading 1
ill go check under the hood
well you where right lol
i have no clue how the alt was not connected, i followed the stock wire and could not find it, it must of been like that for a long time, i found wire and its working
great
Putting your dmm on alt positive should be no different than putting it on batt positive. Your batt pos should be connected to alt pos therefor you should be reading the batt voltage unless car is running then you'll be reading alt voltage. Your connections are bad. Check them.
Edit: you got it
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
Of course I was right, electrical it's what I do lol.
Evo X build log
haha yeah, i just have no idea how i would of missed that.
the wire that im using is the old ground that is poorly soldered and moves but it works till i get wire lol i know it made an improvement bc my voltage didn't
drop as low
drop as low
Are you saying that the positive alt to bat wire is an old 12ga ground wire that has a loose solder joint? You really want to fix that asap. At the very least resolder the terminal.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 2460 Guests (See full list)
