sa 8 v2 Q
I love guys that just sit back and will request a free design. OP, he gave you a design, but you haven't even provided dimensions that are useable. If you want help, ACT like it and engage in the conversation a little bit. Don't just demand a cut sheet dude, it's not a good way to get help.
51 post about the same sub and still asking the same question,
reply the the answer left by others and youll get some help,
people just dont want to wast 1hr+ drawing it up to find it wont fit, just because your too lazy to measure the area or reply with a simply answer, to assist in YOUR OWN BOX DESIGN
I'm not trying to be an ass and just ask questions I'm sorry if I asked for a cut sheet its just I'm not 100 on what measurements or information extra is needed I really appreciate the help because I know its not required for u guys to help me
to help design a box your going to need the maximum dimensions for height, width and depth your able to use, or willing to use...the design john253a posted should work perfectly fine as long as your width and height measurements are correct....depth shouldn't be any problem with 10" of depth....
but what people are saying is that they want to see true measurements for height,width, and depth able to be used, not just a rough guess
people are willing to help they just dont want to feel like your wasting their time by not giving them accurate information
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Ok well this is exactly what I'm measuring 17.5 high 33 wide 33 1/4 in depth all in inches is what I'm measuring for the trunk any additional information needed? N no I would not waste anyones time on here because I understand they are not doing this for the money
here 1 for a 800rms v1.5, thats fits you dimensions,
just another option you may wish to consider (a low power v2 box)
i also allowed for bracing but haven drawn then in
if your after some alternatives on that box (will still need some bracing, witch is alowed for but not drawn in)
OR
another
all of these and more were available within posts on smd
joeX also has a many number of good single v1.5 and v2 drawing floating around on here and a few other sites,
if ant that you fancy, let me no and i can modify them to suit you power and required tune
Holy fucking port. No need for that much port area. That's way too complicated.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
It does seem like a lot but if the box was 0.7net it would be high 16 per ft,
The big thing I've found is the inefficiency of the port in higher power applications, affecting the output of the sub,,
I aim for 9-11sq" at rated or below and 11-12 above, with next to no mercanical limits, the more power the more xmas, the more port
On his power, idd never recomemend that much port,
He just need to find something he feels comfortable to build and we can finalize a design and a hz that he requires, to get the most out of what he has
Lol that is a long port with a ton of 45's and routered edges. I never could have made that my first time. Could a slot port without any L's be done while still having sufficient area, that would be easy to build.
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
  • Who's Online   0 Members, 0 Anonymous, 756 Guests (See full list)
