qcbangin Posted August 13, 2012 Author Report Share Posted August 13, 2012 Can anyone answer my question? I've never built a box with an L port or with 45's. If the port is 3 3/8" wide, does it need to be 3 3/8" wide at the turn? Quote Link to comment Share on other sites More sharing options...
Joe X Posted August 13, 2012 Report Share Posted August 13, 2012 (edited) Can anyone answer my question? I've never built a box with an L port or with 45's. If the port is 3 3/8" wide, does it need to be 3 3/8" wide at the turn? Yes slant or round the inner corner of the turn is recommended, if you are to put a 45 there, you need to make sure is not made too big, the port has to be 3 3/8" AT the turn also. EDIT: if you find hard to make 45s just don't do them, is an optimization only, if don wrong can hurt not help performance. If you have any other questions let me know. Edited August 13, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
john253a Posted August 13, 2012 Report Share Posted August 13, 2012 if you can follow that throught the bend its better, but if not just make sure the l1 and l2 are 3.375" Quote Link to comment Share on other sites More sharing options...
qcbangin Posted August 13, 2012 Author Report Share Posted August 13, 2012 (edited) How big (at the widest point) should the 45 be? I hope you understand what I mean. Example: should I take a 3" strip of wood and 45 it? Do you understand what I'm asking? Edit:you're saying if I put the 45 in port corner than the L has to be rounded too? And I could just not use the 45's? Would it affect it at all if I already have the 45 in the other corner? Its already glued and screwed, so I hope I don't have to remove it. Edited August 13, 2012 by qcbangin Quote Link to comment Share on other sites More sharing options...
Joe X Posted August 13, 2012 Report Share Posted August 13, 2012 How big (at the widest point) should the 45 be? I hope you understand what I mean. Example: should I take a 3" strip of wood and 45 it? Do you understand what I'm asking? If you slant the inner corner of the turn as shown the 45 should be done as follows: Quote Link to comment Share on other sites More sharing options...
qcbangin Posted August 13, 2012 Author Report Share Posted August 13, 2012 Thanks for all the help, and sorry bout so many questions. I didn't cut the 45 in the port wall, so I messed that part up. Did you see my other question? How big (at the widest point) should the 45 be? I hope you understand what I mean. Example: should I take a 3" strip of wood and 45 it? Do you understand what I'm asking? If you slant the inner corner of the turn as shown the 45 should be done as follows: Quote Link to comment Share on other sites More sharing options...
Joe X Posted August 14, 2012 Report Share Posted August 14, 2012 If you have not rounded the corner and not done the 45 in the port turn, never mind it will work regardless. Quote Link to comment Share on other sites More sharing options...
qcbangin Posted August 14, 2012 Author Report Share Posted August 14, 2012 Well, I did round the corner a bit, just not a 45. It's not going to affect the performance without that 45 in the corner? If you have not rounded the corner and not done the 45 in the port turn, never mind it will work regardless. Quote Link to comment Share on other sites More sharing options...
Joe X Posted August 14, 2012 Report Share Posted August 14, 2012 Well, I did round the corner a bit, just not a 45. It's not going to affect the performance without that 45 in the corner? If you have not rounded the corner and not done the 45 in the port turn, never mind it will work regardless. You are ok.. don't worry. Quote Link to comment Share on other sites More sharing options...
stroupe79 Posted August 14, 2012 Report Share Posted August 14, 2012 the 45s in the corners are to help with getting the air to flow better out of the box....it's not required but it would help with performance a little Quote http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
