Ddub847 Posted August 11, 2012 Report Share Posted August 11, 2012 Just wondering is it ok to run odd number of aero ports. Did the calcs and i think 5 4" ports would be ideal. Im runnin 2 15s. box will be around 7 cubes tuned to 32. Any input? Link to comment Share on other sites More sharing options...
bkolfo4 Posted August 11, 2012 Report Share Posted August 11, 2012 It is perfectly fine. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
Ddub847 Posted August 11, 2012 Author Report Share Posted August 11, 2012 Thank you! Link to comment Share on other sites More sharing options...
john253a Posted August 11, 2012 Report Share Posted August 11, 2012 5x 4" is a bit small for 2x 15" in 7net (depending on sub of course) you might get some port noise, have you looked at running 3x 6" aero's you'll also save on ports Link to comment Share on other sites More sharing options...
Ddub847 Posted August 11, 2012 Author Report Share Posted August 11, 2012 9 inches per cube Link to comment Share on other sites More sharing options...
Tim Lam Posted August 11, 2012 Report Share Posted August 11, 2012 IMO i would at least run a single 6" aeroport, maybe if you can find one a 8 or 10". they look more impressive and if flared correctly, less port noise. Link to comment Share on other sites More sharing options...
john253a Posted August 11, 2012 Report Share Posted August 11, 2012 9 is right on the bare minimum, but as i said "depending on sub of course" idd still recommend 3x 6" psp aero as i can see your already lookn at psp as your calculated it at 17"long (there max length) 3x6" @17" long will be 36hz, but you can extend them if you have the space other wise use 6x4" at 17" (35hz) im just not a fan of aero's down that low in port area, i like 11-13, but all comes down to sub Link to comment Share on other sites More sharing options...
Ddub847 Posted August 11, 2012 Author Report Share Posted August 11, 2012 Ight ill do 6 then Link to comment Share on other sites More sharing options...
bkolfo4 Posted August 11, 2012 Report Share Posted August 11, 2012 David Moore was doing ~152-154 (i think that is right, I remember 152.4 or 154.2) on a pair of 15" MT's and 6000 watts a few years ago with 4 4" aeros. . . When will everyone quit being so stuck to port area vs. box size. . . Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
