bass_stalker Posted August 12, 2012 Report Posted August 12, 2012 if my box is 21 inches tall and i have a double baffle would that leave my port 18.75 inches tall? my reasoning ( bottom =.75 inches thick. top = 1.5 inches thick) 1.5 + .75 = 2.25. 21 - 2.25 = 2.25 JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
john253a Posted August 12, 2012 Report Posted August 12, 2012 Yes 18.75" But only if you ticked sub up Put 1 in double baffle And selected 2 or 3 common port walls
revoracing247 Posted August 12, 2012 Report Posted August 12, 2012 idk why this is confusing me but, wouldn't having a double baffle make the port longer? because it has to travel through the extra distance before it escapes out of the box and into unconfined air. ~ If it was easy, everybody would be doing it ~
Torres Posted August 12, 2012 Report Posted August 12, 2012 john is correct. and revoracing, the physical port length shortens in relation to extra baffles. if the port is on the baffle side and is 10" long, the physical port length needs to be 9.25" due to the single baffle. add 1 extra baffle and the physical port length shortens to 8.5", and etc
