explorer.exe is your desktop. try this :
Try running the Virtual Technician to see if it will fix whatever it is: http://mvt.mcafee.com/
If not then try a complete uninstall via Control Panel > Programs > Uninstall a Program
Run the MCPR cleanup tool listed under Useful Links at the top of the page and reboot.
Install the software again from your online account.
If it happens again I would contact Technical Support - it's a free phone call or online chat and also linked under Useful Links.
Last thought, if you are using registry cleaners/optimizers, don't. This is the sort of thing they cause.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
maybe just a total wipe and reboot, my opinion. Wipe, re-partition, and re-download OS if u can manage to download a copy of it.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
if doing a reinstall id just use the recovery partition.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
You might be able to save the files and stuff i would try.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
Well its saying windows detected a problem and is being shut down for protection. The beautiful blue screen.
it seems like mcaffee is fucking with your registry. a reinstall might be the best to do.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
I will have to call them tomorrow cause I can't get anywhere. I was hoping for something simple. I get to the panel it shuts down same with Google or internet explorer. Her lap top was a Christmas gift so still under warranty still. I really thank all you guy for the help.
Posted (edited)
It sounds like your computer is too far gone to fix easily. If you were close to me id look at it for you and fix it. Virus issues arent that hard to fix most of the time but it takes a good amount of experience with them to know how they work and how to kill them.
When you press f8 before windows boots is there an option called "repair your computer"? Usually its the very first option toward the top before it goes into saying safe mode, safe mode with networking, etc. If so there is a slim chance you can get into the command prompt and then type the command to start the combofix program but you HAVE to know the directory its stored under (c:/users/.....) combofix is just a command line utility so you can launch that from just command prompt if needed. If that doesnt work then the easy way out would be to just format the hard drive and start windows fresh. I dont usually recommend doing it but if you are like the 99% of people whose computers i work on and the data is not backed up you could take out the hard drive and install it on another machine to recover your files then wipe windows and start over. Again i dont usually recommend doing this because there is always that chance that the virus is lingering on those files and can unleash itself again.
edit: for your warranty they never cover things like this. All that they would do is erase windows and start it from scratch and charge extra if you need the stuff recovered from the hard drive. Thats the easy way out and a ton of companies do it that way. Its too time consuming for big companies to waste time with looking into why a system crashes and fixing viruses than it is to reimage the computer and leave.
Edited by kickass audio
if he can, i didnt know whether or not he'd be able to use his recovery partition
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 653 Guests (See full list)
