CJs F150 2/19 New videos posted pg 70. 1080p 60fps!!!!
CJ, I'm sure you've done your research and that's why you're doing it, however, is there a moderate increase of current flow potential by using multiple inputs? I would imagine that when wiring below 1ohm is when it would be much more noticeable.
Care to elaborate for a brotha? Looks great btw!
That is a question that I cant give you a technical answer to. AMI CUSTOMS would be the man to answer that. All I can tell you is on my 7.5k, I saw a .5db increase when I added dual inputs. Dual inputs would probably be more than sufficient, but everything in this build is excessive. With 9 power and 9 grounds, I know there will be no choke point. The 9ks will get all of the current that they possibly want, especially running at .5 ohm and at 16.8v.
Wow awesome increase for such a small investment. That's more than enough of an answer. Thanks bro!
Yes adding the multiple inputs does help I have tested it myself and it has been proven by several people. I however prefer copper since I want the greatest possible gain I could get. You also see a much bigger jump in db if you are a routine person who wires very low .25, .33, .5, .66, .7 ohm makes a larger difference in having multiple runs on cable just because the current demand is literally doubled at some of those points of wiring down. Only makes sense to have double the wire. The more conductive material you can have with the least amount of wire resistance, the better it will be for the amp, voltage, and DB!!!!!
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
The tolerances are good, there is clearance. But just incase, I have wrapped the ground blocks in electrical tape.
has it ever happened that those things touch or arc. they have very little space between them.
DC power doesn't arc like AC, they would have to touch. And yes bad things could happen if they held together for any length of time, but just for a second no biggie just might need to check your pants after lol.
Evo X build log
