Thanks genesis
@rmichael91: why yes I did.
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
I either just had an awesome idea, or am about to destroy my enclosure...
More to come...
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
They'll be removable ports so that the length can be adjusted on the fly.
I'll have to sit down and figure up cost. Took about 2 hours to machine, and the aluminum was laying around the shop. Cost me nothing, but I can't use shop machines for profit.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Similar to like those twist locks they have on telescoping poles? Threaded collar that tightens down
Couldnt fab another bracket if I was to cover material and shipping? Technically not profit lol. Not a big deal if that's a no go either
I was originally going to thread the PVC and run that into a coupling, but it seemed more trouble than it was worth. So what I did, is bought 4" pvc unions that have a raised edge in center, and I can cut my pvc to size and slide into this coupling that will be secured halfway through the baffle. I can simply push a port in place and pull it out. They will be held in place by a slight taper.
The block of aluminum would need to be 3" x 3" x 1" IIRC. I'm going to message someone with a mill and see what they can do. I don't know that I can get away with another one right now. I'm in talks of buying a mill off of one of the guys at work, but I haven't even seen it and know nothing of its condition.
Honestly, once the machine is setup (programmed), the run time should be less than 1 hour all together... Having to edge find and mill out the bracket, flip it and fly cut, then flip it on its side and drill out the two holes.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Also, with that bracket, we rotate the alternator 1.75" out of stock position, and the stock belt will not work.
I'll try and get together all of the information for you after the show tomorrow. There was also another bolt that was needed, I believe that was a 3/8- 16 X 2.50" (and the nut for it), but I'll check and let you know for sure.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
We need to meet up... I wanna hear that truck... maybe can talk my girl into letting me put something in my f150 too...
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
