Ive decided to go solo 15" for my build, which will allow me ALOT of box volume for it (between 5-6 cuft max). i was wondering if anybody has had any experience with this brand and what box this sub might like to see? Ive been thinking between 4-4.5 cu ft, but i wanted to see what you guys would recommend me to try and measure for? Ill be using about 2k-2.5k watts. thanks
Seriously off:
http://web.archive.org/web/20061112053902/www.tcsounds.com/lms4000.htm
Would need to model to see how smaller it can be done
3.5^3
If you are getting a custom built sub specs are anyone's guess, it needs to be broken in and then measure t/s params, or take a guess, if that's the exact unit you are getting you should ask the guy to tell the specs they gave him. They took off the LMS coil so it won't perform linear as the original 4000 hope that's what you are wanting.
450 seems kinda cheap for a tc sounds lms woofer. yeah it doesn't even have the original coil, which probably took away a lot of the price.
Break in period varies among subs but usually 200 Hrs (effective) at around 2/3 of xmax will loosen things out enough to make a t/s reading.
  • Who's Online   0 Members, 0 Anonymous, 3377 Guests (See full list)
